nmpuk Posted Friday at 17:31 Share Posted Friday at 17:31 Hi all, Had our Alarm upgraded a while ago, and kept original sounder for various reasons. The panel is an Eaton G2SM panel and the bell / sounder is a Risco Novagard 2. Recently opened the panel to check the exact model, and noticed the green wire from the sounder isn’t connected at the panel end. Everything seems to work ok, the sirens sound and the lights flash when the Alarm is set off and the red LED’s run when not armed. Anyone have any thoughts on how this wire should be connected and whether the rest of the sounder wiring looks ok? Any advice welcome. thanks Nate. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/ Share on other sites More sharing options...
al-yeti Posted Friday at 17:42 Share Posted Friday at 17:42 11 minutes ago, nmpuk said: Hi all, Had our Alarm upgraded a while ago, and kept original sounder for various reasons. The panel is an Eaton G2SM panel and the bell / sounder is a Risco Novagard 2. Recently opened the panel to check the exact model, and noticed the green wire from the sounder isn’t connected at the panel end. Everything seems to work ok, the sirens sound and the lights flash when the Alarm is set off and the red LED’s run when not armed. Anyone have any thoughts on how this wire should be connected and whether the rest of the sounder wiring looks ok? Any advice welcome. thanks Nate. Spare? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530524 Share on other sites More sharing options...
nmpuk Posted Friday at 17:53 Author Share Posted Friday at 17:53 Not sure. Tbh. Managed to get to the sounder and took this pic of the internals. Green is terminated at TMPR at the sounder. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530525 Share on other sites More sharing options...
al-yeti Posted Friday at 18:33 Share Posted Friday at 18:33 (edited) 54 minutes ago, nmpuk said: Not sure. Tbh. Managed to get to the sounder and took this pic of the internals. Green is terminated at TMPR at the sounder. Weird that I thought 0v goes to tmf as a link Then Tmpr goes to the panel tamper return If that at all makes sense Edited Friday at 18:49 by MrHappy Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530526 Share on other sites More sharing options...
MrHappy Posted Friday at 18:39 Share Posted Friday at 18:39 that ↑ + the tamper in linked out in the panel. Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530527 Share on other sites More sharing options...
al-yeti Posted Friday at 18:45 Share Posted Friday at 18:45 4 minutes ago, MrHappy said: that ↑ + the tamper in linked out in the panel. How you split this point to trade ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530528 Share on other sites More sharing options...
MrHappy Posted Friday at 18:50 Share Posted Friday at 18:50 4 minutes ago, al-yeti said: How you split this point to trade ? edited, (good enough ??) Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530529 Share on other sites More sharing options...
nmpuk Posted Friday at 19:21 Author Share Posted Friday at 19:21 Sorry is it not wired correctly? Whats the correct wiring? is tmpf not correct? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530530 Share on other sites More sharing options...
al-yeti Posted Friday at 19:27 Share Posted Friday at 19:27 36 minutes ago, MrHappy said: edited, (good enough ??) No for another discussion lol don't be scared 5 minutes ago, nmpuk said: Sorry is it not wired correctly? Whats the correct wiring? is tmpf not correct? All seemed correct except the link in the panel removed that The link goes in the bell for 0v to tmf Then tmpr white or green doesn't matter goes to the panel bell tmpr , as in leave white where it is and remove the black link in panel If that makes sense Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530531 Share on other sites More sharing options...
nmpuk Posted Friday at 19:35 Author Share Posted Friday at 19:35 Ok, so remove the wire running from 0v to TR, but leave the white cable in TR? And Green to be left as it is? thank you! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47353-eaton-g2sm-panel-and-risco-novagard-2-sounder-wiring/#findComment-530532 Share on other sites More sharing options...
