As above, panel is premier 24, when placing a zone on soak test, do you have to view the event log to see if the zone has triggered an alarm or when unsetting, will the system automatically display that the zone has been triggered ?
Regards.
From what I remember it replaces the banner message with TEST FAILED upon failure, this will display until engineer reset.
Not something used often as you loose the detection while it's on soak.
Thank you.
I realise that zone is not active whilst on soak test, but had two false alarms on same zone 20 minutes apart during the night, (Part set) so rather than be awoken again in the middle of the night, thinking of placing the zone on soak test for a couple of nights just to see if it's a faulty sensor. (PIR)
Regards.
Register a new account
Sign in
