9651 Posted May 13 Share Posted May 13 Evening all Shunt locks Can't find anything about a "graded" shunt lock We don't fit them, (well I have but donkeys years ago) but have one on a current takeover Presume this calls up Does this calls up an existing BS4737 standard or something in 50131? I can't seem to see anything about locks though BS8243 permits a shunt lock for completion of setting - but wondering where we are in terms of component grade? Many thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47249-shunt-locks/ Share on other sites More sharing options...
james.wilson Posted May 14 Share Posted May 14 If there isn't a standard in the suite then you do indeed use the previous std. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47249-shunt-locks/#findComment-529559 Share on other sites More sharing options...
9651 Posted May 14 Author Share Posted May 14 (edited) 59 minutes ago, james.wilson said: If there isn't a standard in the suite then you do indeed use the previous std. thanks James what’s your thoughts on the following? Existing policed system supposed to be grade 3 (not a chance it is imo) Anyway, Galaxy Area on a wing in a Statley Home is being armed / disarmed by this shunt lock alone No local sounders - only one entry exit into the area via this door with the shunt fitted. Currently programmed as keyswitch - 5 second exit. Only one Keypad fitted which is in the main body of the house I’m think this area should have two stage arming - lock programming changed to final - area changed to final set with a local sounder to confirm setting. Keypad then fitted inside the protected area to facilitate disarm on entry - as the lock now programmed as final will disable confirmation on entry Or, am I over thinking it? Edited May 14 by 9651 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47249-shunt-locks/#findComment-529560 Share on other sites More sharing options...
MrHappy Posted May 14 Share Posted May 14 (edited) shunt as in a chubb lock ? or- or Edited May 14 by MrHappy Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47249-shunt-locks/#findComment-529561 Share on other sites More sharing options...
9651 Posted May 14 Author Share Posted May 14 Chubb Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47249-shunt-locks/#findComment-529562 Share on other sites More sharing options...
james.wilson Posted May 15 Share Posted May 15 You can 2 stage arm etc but you can also disarm with the shunt lock. I'd want a local sounder but notification wise depends on signalling and total sounders securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47249-shunt-locks/#findComment-529593 Share on other sites More sharing options...
