Shunt locks
Evening all
Shunt locks
Can't find anything about a "graded" shunt lock
We don't fit them, (well I have but donkeys years ago) but have one on a current takeover
Presume this calls up Does this calls up an existing BS4737 standard or something in 50131? I can't seem to see anything about locks though 🤔
BS8243 permits a shunt lock for completion of setting -  but wondering where we are in terms of component grade?
Many thanks
thanks James
what’s your thoughts on the following?
Existing policed system supposed to be grade 3 (not a chance it is imo)
Anyway,
Galaxy
Area on a wing in a Statley Home is being armed / disarmed by this shunt lock alone
No local sounders - only one entry exit into the area via this door with the shunt fitted. Currently programmed as keyswitch - 5 second exit. Only one Keypad fitted which is in the main body of the house
I’m think this area should have two stage arming - lock programming changed to final - area changed to final set with a local sounder to confirm setting. Keypad then fitted inside the protected area to facilitate disarm on entry - as the lock now programmed as final will disable confirmation on entry
Or, am I over thinking it? 😂
Edited by 9651
shunt as in a chubb lock ?
or-
Edited by MrHappy
You can 2 stage arm etc but you can also disarm with the shunt lock.
I'd want a local sounder but notification wise depends on signalling and total sounders
