Veritasr8
Hello! Im use to installing premier elite, its been a while since i came across a veritasr8.
Ive been instructed to program the zones. The client has 2 zones, can someone guide me on how i program zone 1 as entry/exit and zone 2 as guard,
Im guessing its also 2k24k7?
Thanks
They are double pole unless it's a plus. If your an installer you can get the manual on Texecoms website, that covers panels after 2000.
Any idea how i can set a capture p15 pir to double pole?
3 minutes ago, sixwheeledbeast said:
O/C O/C
And you still wire terminals a and d?
1 minute ago, sixwheeledbeast said:
Double pole is six wires...
So id wire pos and neg...then a b c and d?
Well resolved
10 hours ago, R191 said:
Z1 is entry exit, z2 is guard access and z3 is guard as factory default?
Yep
