Silence loud beeping when arming alarm at night.
Hi all.
I have an Eaton Alarm is Ion g2sm-kpz
Is there any way I can set my Eaton alarm silently at night so it does not disturb people while they are sleeping? Because it makes a loud beeping sound and than sets the alarm after 30 seconds.
Thanking you in advance 🙏
2 hours ago, Ketan said:
Hi all.
In the engineer settings there should be option for silent set
Do you know the steps for this please
If you know engineer code then you can do this and check menus
But if you don't have it ask you installer to do it for you, the benefits of the installer and paying him will put weigh the cost and headache
And if installer has disappeared there's plenty more who can work on this panel
Thank you. Engineer not responding. Can anyone help please 🙏
So what area are you in and we could perhaps find an engineer for you
Edited by al-yeti
  • 2 weeks later...
Hi,
Look for any settings related to "silent arming" or "silent mode." Many alarm systems have an option to arm silently without the beeping sound. Navigate to the settings and see if there's an option to disable entry/exit beeps during arming.
Thanks
9 minutes ago, kieranas said:
Hi,
Thanks
Bit like asking how long is a piece of string, in order to answer your question the essential information required is what system do you have?
Generally all the alarm devices have the same feature that's why I am asking poster to try this. By the way I am using the same device, but I didn't try this.
