hkc shock vibration sensor showing permanently open after moving
I need help I recently moved my hkc shock sensor from window frame to another frame for decorating.
But now when I try and set my alarm it keeps saying zone open some annoying 😑
Some sites say my alignment is off.
I opend it up the sensor has to gold plated cubes could they be misaligned
Look at the cylinder there is an arrow pointer , needs to be pointing up, unless you magnets are to far away
2 hours ago, yazzo said:
Is the cylinder the part with the 2 gold plated magnets 🧲
Yes on the end of it is the arrow
  • james.wilson changed the title to hkc shock vibration sensor showing permanently open after moving
