Zach15 Posted July 28, 2024 Share Posted July 28, 2024 Hello all, I have a Scantronic 9651 home alarm which has been running reliably for many years, recently we had some work done and one of the builders cut a cable to one of the motion sensors, I have since replaced the sensor, the cut wire had also caused a fuse to blow, so I have replaced both the 1amp fuses on the circuit board. I have the user code and the engineers code but now the system is showing Zone flt and goes through all zones 1-5 and therefore won't come out of installer mode?!? Does anyone have any suggestion please? Thank you, Zach. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46849-help-with-scantronic-9651/ Share on other sites More sharing options...
PeterJames Posted July 28, 2024 Share Posted July 28, 2024 99 enter gets you out of engineer Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46849-help-with-scantronic-9651/#findComment-524107 Share on other sites More sharing options...
Zach15 Posted July 28, 2024 Author Share Posted July 28, 2024 Yes I have tried that but because of those zone faults it won't come out of installer mode and the little spanner symbol is showing red. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46849-help-with-scantronic-9651/#findComment-524108 Share on other sites More sharing options...
al-yeti Posted July 28, 2024 Share Posted July 28, 2024 (edited) 1 hour ago, Zach15 said: Yes I have tried that but because of those zone faults it won't come out of installer mode and the little spanner symbol is showing red. Then tamper might be open if it's running through the zones , meaning it's setup as global tamper and you haven't connected the tamper and.zone wires correctly Or you selected a menu by mistake and pressed default? Edited July 28, 2024 by al-yeti Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46849-help-with-scantronic-9651/#findComment-524109 Share on other sites More sharing options...
