March 11, 20242 yr comment_521864 Hi folks, moved into a new home and managed to change codes and have the alarm working. however am unable to use Part alarm, so that upper floors can be isolated at night. Manual says enter code, Press P and the exit tone should stop , allowing you to choose which zone you want to part alarm. However the exit tone doesn't stop and no new menu options come up. Help... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46515-accenta-gen4-honeywell-alarm/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 11, 20242 yr comment_521865 7 minutes ago, Alarm novice said: Hi folks, moved into a new home and managed to change codes and have the alarm working. however am unable to use Part alarm, so that upper floors can be isolated at night. Manual says enter code, Press P and the exit tone should stop , allowing you to choose which zone you want to part alarm. However the exit tone doesn't stop and no new menu options come up. Help... Don't you have to set the zones up for part set first? In settings ? Then that might work ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46515-accenta-gen4-honeywell-alarm/#findComment-521865 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 11, 20242 yr Author comment_521866 I didnt want to mess with the original settings, as I am sure the previous owners had part set up already. I did a walk through test and all the different zones were picked up. However what you suggested may be worth doing. thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46515-accenta-gen4-honeywell-alarm/#findComment-521866 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 11, 20242 yr comment_521868 Reprogramming it all is best , to make sure it all works to how you want it to, but If you got the budget get rid of it when you can Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46515-accenta-gen4-honeywell-alarm/#findComment-521868 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 11, 20242 yr Author comment_521869 may have to go into engineering settings for that which could prove tricky or need another code. anyhow why do you suggest getting rid or replacing this one? not fit for function? alarm for a 3 storey townhouse in a gated area ?any recommendations ? thanks for your responses Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46515-accenta-gen4-honeywell-alarm/#findComment-521869 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 11, 20242 yr comment_521870 as al says you will need to setup the partsets in programming. they are dsiabled by default securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46515-accenta-gen4-honeywell-alarm/#findComment-521870 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 12, 20242 yr comment_521888 22 hours ago, Alarm novice said: may have to go into engineering settings for that which could prove tricky or need another code. anyhow why do you suggest getting rid or replacing this one? not fit for function? alarm for a 3 storey townhouse in a gated area ?any recommendations ? thanks for your responses It's old panel dude , just like anything else it may do the job if it works for a bit , but realistically I am sure as SW would say not using a Nokia version 1 to post your messages ....... DIY although one way I can only say go scantronics ion which still uses a free based app system and is less complication other systems Others that are free either poor hardware or complicated programming Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46515-accenta-gen4-honeywell-alarm/#findComment-521888 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
