NEWDIY Posted October 10, 2023 Share Posted October 10, 2023 Hello, I have just installed a new Pyronix Deltabell plus and a new battery for the alarm panel. (Citydell XR2) As soon as I power it up from either the mains or connecting the battery it goes straight into tamper mode. (Even if the tamper spring is depressed) I can then input my code to silence the alarm, but after this the keypad goes dead. I cannot get it out of tamper mode and none of the keys make a noise when pressed like they usually do ! I’ve checked the tamper on the deltabell plus and the cover is definitely pressing the switch down. Any advice ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46150-xr2-stuck-in-tamper-mode/ Share on other sites More sharing options...
NEWDIY Posted October 10, 2023 Author Share Posted October 10, 2023 13 minutes ago, NEWDIY said: XR2 Apologies it is a XRI Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46150-xr2-stuck-in-tamper-mode/#findComment-520392 Share on other sites More sharing options...
james.wilson Posted October 10, 2023 Share Posted October 10, 2023 the tamper is probably global, not just the tamper spring on the panel. One of them will be open circuit either the sab you have replaced or the tamper input securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46150-xr2-stuck-in-tamper-mode/#findComment-520393 Share on other sites More sharing options...
NEWDIY Posted October 10, 2023 Author Share Posted October 10, 2023 29 minutes ago, james.wilson said: the tamper is probably global, not just the tamper spring on the panel. One of them will be open circuit either the sab you have replaced or the tamper input So in basic terms something isn’t wired correctly ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46150-xr2-stuck-in-tamper-mode/#findComment-520394 Share on other sites More sharing options...
sixwheeledbeast Posted October 10, 2023 Share Posted October 10, 2023 In basic terms it could be anything. A multimeter and knowledge of how to use it would be a start. System is likely in tamper lockout, find the tamper find the fault. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46150-xr2-stuck-in-tamper-mode/#findComment-520395 Share on other sites More sharing options...
