IP drop out
al-yeti
A dodgy or misconfigured anything on the network "could" cause it. Have to try and isolate to narrow it down somehow.
You should be able to calculate what bandwidth should be on each link if you add up all the equipment.
I guess these are unmanaged switches so you can't look at logs or change any QoS/Bandwidth settings etc.
Correct all unmanaged
But I get what your all saying , thanks for the guidance will look into it
