Texecom premier elite screw nut broken
Hi
I just installed a texecom premier elite metal panel but the screw nut has snapped so lid wont fasten, any ideas what to use instead? Can you get replacement?
Edited by Figgy100
ebay or ask texecom
u nut, fairing clip everybody calls the the same item a different name
If you fit a lot of Texecom speak with your rep they should be able to sort you out.
If not they are called U clips, you will need to find the right size I think they are M5 from memory
Edited by sixwheeledbeast
5 not 6
New Premiers come with a spare in the little plastic pouch along with a spare fuse and mains terminal cover?
No spare that's the one for the cab and we are assuming it's the U clip/nut not the bolt/screw
