Veritas R8 Communicator pins
Hi,
I’ve got a Veritas R8 Panel that I have tapped in to a couple of the communicator outputs to identify through a home automation system whether the panel is armed or whether the alarm has been triggered.
Is there a way I can identify if the panel has been  part set vs full set through any of the communicator outputs ?
  • Replies 28
  • Views 5.4k
  • put your pile of poo veritas in the bin & buy a pile of poo premier to go in it place   if you can't afford less than £200 to buy some better controls you shouldn't be bothering to autom
I doubt a basic panel like the veritas can but there maybe a programmable output. On the better panels you can
r8+ has 8 channels, line monitor & remote reset
programable channels?
fixed (irrc) anticode reset too.
It’s the R8+ I have
Sadly the engineer code isn’t known and it’s been changed from the default. I’m reluctant to reset the panel in case the engineer code has been locked.. but I’ve been able to use the communicator outputs for the basics of what I need...
What does the line monitor output provide ?
Edited by DanEdge
no, we did have some on 8440's or those csl digi's
there really was'nt much n the way of space or current...
input, removes bell delay when there's a telephone line fault
Thanks. What does the zone lockout provide?
zone omit notification to the arc
