July 16, 20197 yr comment_486238 Hi there, Any help would be appreciated. We have installed a couple of FLIR thermal IP cameras which were setup to record on a HikVision NVR. However one of the cameras is no longer connected & displays the 'network unreachable' error in the camera setup section. They are also linked to a Davantis unit too and work fine on there? Contacted tech support who were about as much use as a chocolate fire guard! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42939-flir-ip-cameras/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 17, 20196 yr comment_486246 I'd assume you have checked you can ping them etc from the dvr location. How are the wired, multiple switches etc? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42939-flir-ip-cameras/#findComment-486246 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 17, 20196 yr Author comment_486277 I can ping them yes & I can also view the streams via web browser too. Both online on the Davantis like I said before. There are multiple switches I believe too. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42939-flir-ip-cameras/#findComment-486277 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 17, 20196 yr comment_486280 so when on the poe switch of the nvr you can ping them? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42939-flir-ip-cameras/#findComment-486280 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 18, 20196 yr comment_486286 On 16/07/2019 at 18:35, Hutch4891 said: Hi there, Any help would be appreciated. We have installed a couple of FLIR thermal IP cameras which were setup to record on a HikVision NVR. However one of the cameras is no longer connected & displays the 'network unreachable' error in the camera setup section. They are also linked to a Davantis unit too and work fine on there? Contacted tech support who were about as much use as a chocolate fire guard! Are they onvif? Or specific setup? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42939-flir-ip-cameras/#findComment-486286 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 18, 20196 yr Author comment_486312 They are ONVIF that is correct & yes I can ping them Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42939-flir-ip-cameras/#findComment-486312 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
