Hard wired bell to visonic
7 minutes ago, little_john said:
J4 can be selected as G3 / G2 ?, and J8 will set to ext,  i cannot test it again until monday, just want to say thanks for your input with this.
Can't remember now about that jumper , but if it solves problem then select g2 if it doesn't then put the resistor in correct place
cheers
