paul44 Posted October 28, 2018 Share Posted October 28, 2018 Hi, do theses panels have built in speech diallers to alert the customer directly, or do you need a external dialler. Ive never worked on them before so not sure. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42479-galaxy-2-44/ Share on other sites More sharing options...
al-yeti Posted October 28, 2018 Share Posted October 28, 2018 2 minutes ago, paul44 said: Hi, do theses panels have built in speech diallers to alert the customer directly, or do you need a external dialler. Ive never worked on them before so not sure. External dialler required , coms device onboard won't work for you unless you connected to an arc You could opt for selfmon if you want something in-between search online Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42479-galaxy-2-44/#findComment-480299 Share on other sites More sharing options...
paul44 Posted October 28, 2018 Author Share Posted October 28, 2018 Cheers for the quick response al-yeti Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42479-galaxy-2-44/#findComment-480300 Share on other sites More sharing options...
