Pyronics enforcer V10 wiring to Deltabell E
Hi so I got the Deltabell and tried to wire it to the Enforcer panel. The problem I have is that when I arm the panel the Deltabell goes off!
Please would someone advise me how to wire it including where the jumpers should be. I've set the jumper to SCB mode not sure about the rest. Thanks
Can you send pictures how your wired it or drawing or aomething
I tried to upload a photo but the file is to big so :
deltabell: from the top terminal
white_T
resistor_T
eng hold_ none
stb_yellow
bell_green
12v_red
negative_black also resistor into this terminal linked in to 2nd T above
Enforcer panel
Red_12v+
Black_common
Green_bell
Stb_yellow
White_D1
No links or resistors in panel
Frustrating grrr
Thanks
white_T
resistor_T
eng hold_ none
stb_yellow
bell_green
12v_red
Enforcer panel
Red_12v+
Black_common
Green_bell
Stb_yellow
White_D1
Frustrating grrr
Thanks
4 hours ago, Sirenblinky said:
Here are some pics
Why is resistor there?
Just put a striaght link in
Also I think your white wire needs to go to z33 and z33 is programmable in menu as a bell tamper , z33 normally has the resistor on it in series so like white wire connects to resistor and then resistor goes into z33 , resistor mostly goes in bell , but your in bench DIY unit won't matter
Been a while since I did this , isn't D- , zero volts so that's where the black would go ?
Edited by al-yeti
D- to 0v
D+ to 12v
STB to STB
Bell to bell
Z33 to T
Then leave resistor as you have it, you have a 4k7 there which needs to be also programmed in wiring selection choice menu
