September 6, 20187 yr comment_479034 I have installed the alarm and programed including adding a smartcom wifi. My question is, currently i have all my pirs assigned to one zone. If I want to part arm the system at night, thereby not having upstairs pirs active, how do i do this in programming . I am using wintex. Is it to do with ticking part emit 1 on those sensors? Edited September 6, 20187 yr by donut Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42369-texecom-48w/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 6, 20187 yr Author comment_479042 This probably answers my question 1 - PART 1 OMIT Zones with this attribute will be omitted when ‘Part Arm 1’ is selected. Zones without this attribute will respond as normal. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42369-texecom-48w/#findComment-479042 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 7, 20187 yr comment_479063 Helps when you read the manual. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42369-texecom-48w/#findComment-479063 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 7, 20187 yr Author comment_479068 3 hours ago, sixwheeledbeast said: Helps when you read the manual. Several times Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42369-texecom-48w/#findComment-479068 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 8, 20187 yr comment_479076 On 06/09/2018 at 13:30, donut said: I have installed the alarm and programed including adding a smartcom wifi. My question is, currently i have all my pirs assigned to one zone. If I want to part arm the system at night, thereby not having upstairs pirs active, how do i do this in programming . I am using wintex. Is it to do with ticking part emit 1 on those sensors? Although I’m having learning issues with my new wireless system, I have used Texecom for several years. You need to break your system into zones rather than omitting sensors. I have my downstairs/conservatory and garage on 1 zone and upstairs on another. We had a keypad upstairs so when we go to bed we “part” set the system which secures downstairs/conservatory and garage(pir’s and contacts) but leaves the 1st floor off so that we can move around/bathroom etc. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42369-texecom-48w/#findComment-479076 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 8, 20187 yr comment_479077 Zones, Areas and Part sets are all different things Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42369-texecom-48w/#findComment-479077 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
