Bradynew Posted August 16, 2018 Share Posted August 16, 2018 (edited) I am trying to install Scantronic 9448+ control panel but i am facing a problem with my EE zone and Zone 3 as i set it for Entry Exit as well. The alarm does not go off in the external sounder (Bell) for Entry Exit Zones, it only goes off in the Internal Sounder. Is there a way to over come this problem. Thank you. Edited August 16, 2018 by Bradynew Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 16, 2018 Share Posted August 16, 2018 Bell delay for E/E timeout? For some reason called "Dual Ply" delay on Scanny. Quote Link to comment Share on other sites More sharing options...
Bradynew Posted August 16, 2018 Author Share Posted August 16, 2018 (edited) If I disable Dual Ply the external sounder will go of immediately after my Entry/Exit time for EE zones? Edited August 16, 2018 by Bradynew Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 16, 2018 Share Posted August 16, 2018 1 hour ago, Bradynew said: If I disable Dual Ply the external sounder will go of immediately after my Entry/Exit time for EE zones? After the entry time expires it should go into alarm correct Quote Link to comment Share on other sites More sharing options...
aissecur Posted August 20, 2018 Share Posted August 20, 2018 Only Just seen this, Are you part setting the system? If so you have a part set response on the programming menu (it can either be full alarm or internal sounder only) Quote Link to comment Share on other sites More sharing options...
