Menvier TS690
Good Evening
I was working on a TS690 this afternoon and I set up a new ward partition C. However when i trigger a device in that ward it is not registering an alarm not audible or even in the log.
If i full set the premises everything works as it should. I have looked in the menu option 'configure wards'.
Any ideas?
Is the 690 not programmed the opposite to what you normally do in that the zones you think are included are excluded, I'm sure I had this years ago and that was the only way I got it working
Trade Member
It's likely the part sets are set incorrectly.
You have to both configure the Wards included and configure the zones included for in that ward separately.
So one you've congifigured your new ward C added what circuits you want into that zone... what is the next step? The menu option configure wards seems to have limited options not a lot you can add/change.
Thanks
