Swann DVR8-4000 which Hikvision cameras are compatible?
They're doing deals on boxer shorts and door contacts this weekend #blackfriweek
Needs some new ones. How many pairs can I get if I do a 299 special?
Edited by sjsturner
That's not what you said 5 minutes ago!
on a serious note I'm getting my boxers from Enterprise. Only to be told its on back order. Both are waiting on Debenhams to deliver
14 hours ago, sjsturner said:
as above best to replace it all dude, if I was going DIY I deffo wouldn’t buy Swann again.
in regards to Hik, even the pros that don’t like it know it’s half decent kit especially for DIY market.
i doubt you will find anyone on here that has dealt with Hiwatch, this is the new Downrated version of Hikvision kit designed to obliterate Swann and the like
3
Thanks, SJSTURNER, I didn't realise that.
Try CCTVTEK for your CCTV DIY kits. They sell a lot of HIKVISION, prices are great and they offer support should you require it.
Is your current system IP or standard? You can use CAT5 or coax for the HD analogue stuff which I’ve had good results from
