March 5, 20179 yr comment_459957 Hello, Looking like an interesting forum; currently have a collection of Visonic parts mainly eBay purchases now looking at making them all work. I've won as apart of some of my purchases a Visonic PowerMaster 360. The first real issue so far is default installer code. I've factory reset the panel, can access it via Power Master configuration version 1.0.3.04 using the default 'user' (in some manuals) code of However when I come to entering either the master code, or installer code of it's throwing me a 'wrong password' error. The panel looks to be an ADT thus I suspect the firmware could be different. Any ideas of processing forward. PM possible installer codes? Or does anyone have any default Visonic Firmware I can upload to the box. Thanks in advance Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41030-hi-visonic-install/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 5, 20179 yr comment_459960 Hi Welcome We are unable to give out any defaulting information on this forum for obvious reasons Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41030-hi-visonic-install/#findComment-459960 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 26, 20206 yr comment_505033 Hi Theengdom, Did you get anywhere with your ADT PM360R as I'm in the same position as you. Regards Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41030-hi-visonic-install/#findComment-505033 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 26, 20206 yr comment_505041 4 hours ago, PTD said: Hi Theengdom, Did you get anywhere with your ADT PM360R as I'm in the same position as you. Regards Yes many are Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41030-hi-visonic-install/#findComment-505041 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
