Europlex / SPC question again...
I've got an older SPC keypad which has no addressing wheels (but otherwise identical looking to Siemens / Vanderbilt models)
There are two ports / pins on the top left rear, one marked 'Z8'. These are present on newer PCBs but without the pins.
However, even on the older keypad there are no jumpers fitted (at least on my one) and no numbers marked...
How do you set / address these older keypads...?
Edited by datadiffusion
auto address only?
is it a Siemens one or a europlex one?
I imagine a Europlex era one, but warranty expired 08/2009 so not that ancient...
Oh yeah its grey alright, but SPC was around pre Siemens takeover, right?
yeah but it was a europlex signet then
But still Compatible?
Anyway, on to todays other query.
Siemens eline DTs all within 4m of panel or expander, 3 out of 4 showing 'poor' on Eol, yet showing as 2.2k on the nail... Built in eol, copper cable.
One mc right under expander and pir next to panel showing 2.2k but 'ok'.
All are ok when open....
I changed eol tolerence to 'wide' but seems very fussy???
Does SPC not really like non Siemens values?? dread to think what happens on galaxy values on long CCA wires.
usually use 1k 1k etc but on grade 3 optex built in don't have a default that fits
But does the SPC grumble about 'poor values'?
