Risco Agility - stays in exit mode forever
Buttons
A couple of times a week, my Risco Agility 3 will fail to arm fully. When I get home, hours later, the voice is still saying "Please exit now".  This only happens when I set it from the front panel - it always works perfectly if I set from the smartphone app.
I've tried changing the sensor batteries. Do do you know what might be causing this?
Edited by Buttons
11 minutes ago, PeterJames said:
door contact stuck in closed position
Thanks - that makes sense. Do you know what might cause that to happen intermittently? Is it likely to be a badly-positioned contact or a faulty one? Just trying to work out how to fix it.
4 minutes ago, PeterJames said:
Slamming the door causes the glass tube to break or crack then the damp gets on the contact and they stick together
The only way to fix it is to replace the door contact
Wouldn't that break it permanently though? This only happens once or twice a week. The rest of the time it works fine.
