d8ug1e_86 Posted November 29, 2015 Share Posted November 29, 2015 Fitted new gd48 with rf portal.programmed sensors all ok but keyfobs will not learn on.any suggestions on how to do it please? Link to comment Share on other sites More sharing options...
al-yeti Posted November 29, 2015 Share Posted November 29, 2015 Portal version perhaps? Did you try changing the protocol on the remote? Link to comment Share on other sites More sharing options...
andy82 Posted November 29, 2015 Share Posted November 29, 2015 Fitted new gd48 with rf portal.programmed sensors all ok but keyfobs will not learn on.any suggestions on how to do it please? The fobs are programmed through the user codes Link to comment Share on other sites More sharing options...
al-yeti Posted November 29, 2015 Share Posted November 29, 2015 The fobs are programmed through the user codes Lol of course I should have mentioned that first , house bashing ain't easy I tell ya Link to comment Share on other sites More sharing options...
d8ug1e_86 Posted November 29, 2015 Author Share Posted November 29, 2015 I went into user codes then option 11 rf fob.u press *for auto learn and it says learning fob or something.instructions say you hold buttons 1 and 2 on fob for a couple of secs but it doesn't learn.how do you change protocol? Link to comment Share on other sites More sharing options...
al-yeti Posted November 29, 2015 Share Posted November 29, 2015 When you insert battery I think it lights up, if it's right one I am talking about you hold the opp two buttons as put in battery So disarm/part arm for one protocol And Full-total arm / disarm for other protocol One of them should make it work Its in instructions Link to comment Share on other sites More sharing options...
d8ug1e_86 Posted November 29, 2015 Author Share Posted November 29, 2015 Al try that 2moro mate Link to comment Share on other sites More sharing options...
