ezki1 Posted October 11, 2015 Share Posted October 11, 2015 Hi guys, Fitted my first camera job today in brothers house, dvr is a hikvision turbo x 2 cameras are hdtvi cameras, we originally set up on a bench to test everything and all fine , so we installed today, powered up first camera and everything fine, powered up second camera and both images are getting a ghostly rolling image of each other ? Both cameras are wired independently in cat6, with baluns. Each camera works fine when the other is not booted up, problem is only when both powerd up. Cameras are powered by a 12v 5a inline transformer with 4 way splitter ( obviously only 2 being used). I have powered one camera from the transformer and the other from my test monitor which helps greatly but still a faint image on both sides. Unsure what to do now, any help would be great thanks. All connections have been checked and rechecked. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/ Share on other sites More sharing options...
timmo66 Posted October 11, 2015 Share Posted October 11, 2015 what happens if you power cameras from separate power supplies? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432310 Share on other sites More sharing options...
shieldssecurity Posted October 11, 2015 Share Posted October 11, 2015 sounds like you've mixed the pairs of the Cat 5 "25 years of experience has taught us to care about the smaller jobs and given us the expertise to succeed in the larger ones" Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432313 Share on other sites More sharing options...
ezki1 Posted October 11, 2015 Author Share Posted October 11, 2015 timmo66, it helps a great deal, but the problem is still there but very faint. shieldssecurity, i assume your talking about the balun side of things, would it not work at all if you got the video pos neg mixed up, as when you dis one camera the other camera works fine, its only when they are both plugged into the dvr, ( i have tried different combinations of channels). Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432319 Share on other sites More sharing options...
al-yeti Posted October 11, 2015 Share Posted October 11, 2015 Ez What he's possibly asking is if you u twisted all the pair's and got the legs mixed up, although I understand what you mean to Is the cat6 shielded? As on bench length would short , others here have mentioned about this Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432320 Share on other sites More sharing options...
Serg Posted October 11, 2015 Share Posted October 11, 2015 Extra to above Ghostly image may be result of wrong end of line termination of video signal. Any T-BNC in the system or loop through devices like monitors? I also would check transformer what may not provide decent noise filtration. Power up both cameras form battery source. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432331 Share on other sites More sharing options...
al-yeti Posted October 11, 2015 Share Posted October 11, 2015 Get better baluns Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432332 Share on other sites More sharing options...
shieldssecurity Posted October 11, 2015 Share Posted October 11, 2015 The same thing happened to me once when I used twisted pair. I used blue/white and orange/white for one balun and white/blue and white/orange for the other and got ghosting. when I kept both blues on one balun and both oranges on the other, the problem was sorted.. "25 years of experience has taught us to care about the smaller jobs and given us the expertise to succeed in the larger ones" Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432333 Share on other sites More sharing options...
Adi Posted October 11, 2015 Share Posted October 11, 2015 Why would you not use the twisted pair as you should. I really can't be ar**** with it anymore. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432334 Share on other sites More sharing options...
shieldssecurity Posted October 12, 2015 Share Posted October 12, 2015 Why would you not use the twisted pair as you should. I was young "25 years of experience has taught us to care about the smaller jobs and given us the expertise to succeed in the larger ones" Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39208-my-1st-camera-installationproblems/#findComment-432336 Share on other sites More sharing options...
