ensecurity Posted July 17, 2015 Share Posted July 17, 2015 Evening all, I've recently changed the lounge and conservatory door contacts to Viper GL shocks, however I don't like the behaviour of the LED. It flashes when normal and goes off when the detector is activated. Is there a way to stop that behaviour? I'd only want the LED to come on when the detector is activated. I have 8 core cable running to each Viper. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38798-viper-gl-led/ Share on other sites More sharing options...
charlie6 Posted July 17, 2015 Share Posted July 17, 2015 Dependant on the detector, the led may flash intermittently to indicate that it is functioning correctly (open to comment !!). There may be a 'disable' or 'latch' facility (good on you for using 8 core). Is the led disturbing you in some way ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38798-viper-gl-led/#findComment-424435 Share on other sites More sharing options...
james.wilson Posted July 18, 2015 Share Posted July 18, 2015 its default that way but you can change it on the glx, enable and wire the fta and change the reset from auto securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38798-viper-gl-led/#findComment-424445 Share on other sites More sharing options...
