Premier 88 Bell On Confirm
All Premier 88 PCB’s prior to issue 13 were fitted with two 24LC128 in the sockets labelled U9 and U10.
From issue 13 onwards, they were fitted with a single 24LC256 in the socket labelled U10. If the PCB is
prior to issue 13 or has two 24LC128 fitted, they must be removed and a single 24LC256 fitted to the
I seem to remember that there is a year date on the pcb, the year date determines what software can be put in. I know that v8 needed more memory to cope with extra functions/ more log events
There you go, spot on PSE
