al-yeti Posted February 16, 2015 Share Posted February 16, 2015 Maybe it's wrong code and you locked yourself out? I wonder does engineers access need to be granted before trying to access all menus I don't really know this panel Quote Link to comment Share on other sites More sharing options...
m300raj Posted February 16, 2015 Author Share Posted February 16, 2015 I have both grand master and engineers codes and they will not let me access any area Quote Link to comment Share on other sites More sharing options...
morph Posted February 16, 2015 Share Posted February 16, 2015 The problem is that you don't really know what your doing and trying lots of things hoping they work only introduces further issues that because your not familiar with the system. I would be inclined to wipe everything and start again. 1 Quote Link to comment Share on other sites More sharing options...
m300raj Posted February 16, 2015 Author Share Posted February 16, 2015 This system took a while to program to work just right I don't fancy doing it all again for the sake of a simple anti code. I wish I had downloaded the software when I had access to risco site. I will pursue tying to find someone willing to help in the meantime I have CCTV which I can access remotely to keep an eye on the place. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 16, 2015 Share Posted February 16, 2015 Anticode? Set by you on original installer ? It's set for anticode so user can't reset it , hence why you can't get into engineer mode either because perhaps code is incorrect Sorry bit strange really, it's straight forward to programme Quote Link to comment Share on other sites More sharing options...
m300raj Posted February 17, 2015 Author Share Posted February 17, 2015 Ok I have looked into fault codes can someone tell me what P1 ET means Thanks Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 17, 2015 Share Posted February 17, 2015 Exit terminator ie what ever is used for exit setting perhaps Why do you think it's a fault code? P1 could just be partion 1 Your trying to guess your way round the panel and your questions will be endless if you installed it you must have the manual its all in there hope it works out or get an installer to sort it for you Quote Link to comment Share on other sites More sharing options...
m300raj Posted February 17, 2015 Author Share Posted February 17, 2015 Sorry looked at wrong menu there is a fault system clock N Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 17, 2015 Share Posted February 17, 2015 then set it Quote Link to comment Share on other sites More sharing options...
m300raj Posted February 19, 2015 Author Share Posted February 19, 2015 I would if it would let me Quote Link to comment Share on other sites More sharing options...
