Bell Box Module Wiring Interface Help
paulwike
Hi,
Im a newbie to this site.  I have an old Scantronic 9200 - well 9210 alarm and remote keypad (please dont laugh i loved the 80's),  after a lot of reseting i have managed to get it all working with the internal speaker.   I want to create a mini bell box module circuit which will flick a relay when the alarm is triggered , but to do this i need to understand the interface from the control panel and i'm clutching at straws atm - any help is appreciated ;-0
I have the following from the alarm control box :
Pin 1 - TRIG + / Hold + (constant + power supply  ??????)
Pin 2 - TRIG - /  -VE RINGING
Pin 3 - 0v  / Hold - (constant - power supply ????)
Pin 4 - TR /  -VE Tamper return.
Im assuming that i can user P1 and P3 as a power supply (regardless of the alarm being triggered or not).
what isnt clear is how:
  • I put together the tamper circuit (I'm guessing P4 is involved)
  • Detect if the alarm has been triggered which I'm guessing will need to involve P2 ?
Im probably over complicating things but any help is appreciated .
Paul.
Im a bit lost as to what you're trying to do, are you just trying to connect a modern external siren?
Pin 4 is just looking for 0v through a tamper switch etc... to show all is ok.
1 and 3 are just constant power as you say, 2 goes Neg in an alarm situation
Hope this helps!
Hi,  Thanks for the reply and your help.   Yes I want to use a relay so I can connect in a strobe and possibly switch on / off some other things....
Pin 2 - so this will be 0v when the alarm is triggered ?   does that mean it will be positive (12v) when the alarm hasn't been triggered ?
Paul.
Pin 1 is 12v
Pin 2 will switch to 0v when alarm triggers
So relay between them Will switch , you need a diode on that relay I think
Providing what you said above is correct
Don't you have a multimeter , otherwise buy one and yesterday it , very cheap these days and always useful
Thanks ,  Yes i have a multimeter and thanks to your responses i kind of know what to check,   its been a while since ive done any electronics work so apologies for all of the questions ;-)
so is pin 2 an open circuit initially and then when the alarm triggers it switches to 0v ?
