Honeywell Galaxy G2-12
Hine1789
Alrite guys i' m back and need your help again. I am wanting to connect another sounder to my panel but this time i have a klaxon sonos 230v one. I connect this the same but will need a transformer to change the 12 v to 230v and also can i wire it the same terminals? I have answered my own question but just.need to clarify. Thanks in advance
That's a Fire sounder right ?
You will need to fit a suitably rated relay in order to switch 240VAC from 12VDC.
Something like this will work. You may want to source something with appropriate approvals markings.  This one is rail mount - I normally work with rails to keep things neat in the panel.
http://www.ebay.co.uk/itm/DIN-Rail-Mount-2-SPDT-10A-Power-Relay-Interface-Module-12V-Version-/161168508254?hash=item258664455e
Edited by GalaxyGuy
