soulstyle Posted June 4, 2010 Share Posted June 4, 2010 I have a menvier security panel wired to a SD1+, Which is fine. I now have an ZP3 installed and the fire company has supplied me with contacts from their panel. They are using the Ziton ZP3 fire contacts which are about +5v normal and switch to +24 on fire. Question. How can i connect this into my dialler as i cant seem to get it to trigger when i test? Link to comment Share on other sites More sharing options...
A-G Posted June 4, 2010 Share Posted June 4, 2010 I have a menvier security panel wired to a SD1+, Which is fine. I now have an ZP3 installed and the fire company has supplied me with contacts from their panel. They are using the Ziton ZP3 fire contacts which are about +5v normal and switch to +24 on fire. Question. How can i connect this into my dialler as i cant seem to get it to trigger when i test? You'll need to use a relay between the fire panel and the dialler. Do you understand how to wire a relay? . . . PM me for access to the SSAIB members discussion area. Link to comment Share on other sites More sharing options...
james.wilson Posted June 4, 2010 Share Posted June 4, 2010 as above you will need to use a relay from the fire panel. Id suggest wiring between common and Normally open on the relay, and connect that to 0v on the dialler and trigger B (or whichever trigger your using) However dont mess with a fire alarm as a rule they are a life safety system and you could affect its operation. Also IMHO you shouldnt use a speech dialler for anything important but thats a whole seperate subject. James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
