Double Pole Contact Grade 2?
Its just a tamper switch that would press against the frame, you still need to fit Eol but its the same size as the old surface contacts.
Grade 2
Handy to know, also means its an ideal van stock part if they retro fit
Guest anguscanplay
on the subject has anyone experienced problems with the G3 CQR pre resisted maximal style contacts on Galaxy's
only when he cut the links but didnt seperate them enough
Grade 2
whoo hoo - took em long enough to see the light, when are they on sale?
