RicherT Posted March 24, 2008 Share Posted March 24, 2008 Dear all, Have just installed a the above unit, gone into engineer prog mode (like the manual says). Keyed in zero to commence walk test and then the unit makes an intermittent beeping sound, with all 8 LEDs glowing. Something is not right here as the manual indicates that the 8 LEDs should be off and would come on when one walks in front of the respective PIR unit. Does anyone have an idea what could be the problem. Many thanks RicherT Link to comment Share on other sites More sharing options...
RicherT Posted March 24, 2008 Author Share Posted March 24, 2008 Also, I would like to point out that I have 5 no. PIRs wired to the panel. 1 PIR per zone. RicherT Link to comment Share on other sites More sharing options...
iSTORM Posted March 24, 2008 Share Posted March 24, 2008 Do you have power at your detectors? My Name is Iain iStorm Security Solutions Visit My Website Link to comment Share on other sites More sharing options...
RicherT Posted March 24, 2008 Author Share Posted March 24, 2008 Do you have power at your detectors? Thanks for your prompt response All 5 PIRs will glow when you walk passed them so (and turn off after a few seconds) - so yes I would assume that power is going to all detectors. Richer T Link to comment Share on other sites More sharing options...
iSTORM Posted March 24, 2008 Share Posted March 24, 2008 have you wired the panel end correctly? Take all your cables out of the zones and install links in them, then try it again, if it clears you have the wired the panel incorrectly. My Name is Iain iStorm Security Solutions Visit My Website Link to comment Share on other sites More sharing options...
RicherT Posted March 24, 2008 Author Share Posted March 24, 2008 Hi iSTORM, Well, pleased top say it works....(or at least the first zone is wired up - using the link as suggested) and the walk test functions as it should. Will carry on with the other zones in the same manner and this should be problem solved. Many many thanks. Regards RicherT Link to comment Share on other sites More sharing options...
alterEGO Posted March 24, 2008 Share Posted March 24, 2008 Hi iSTORM,Well, pleased top say it works....(or at least the first zone is wired up - using the link as suggested) and the walk test functions as it should. Will carry on with the other zones in the same manner and this should be problem solved. Many many thanks. Regards RicherT no no, no. The zone will not work with the link left in, it will not activate if the alarm is set. istorm ment put the link in as a test, by doing this you have proven you have wired the sensors incorrectly. you need to find your alarm pair. what colour cores have you wired into the two PIR alarm terminals[C,NC], you need to put the same two colours in the zone terminals at the panel. Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted March 24, 2008 Share Posted March 24, 2008 Hi iSTORM,Well, pleased top say it works....(or at least the first zone is wired up - using the link as suggested) and the walk test functions as it should. Will carry on with the other zones in the same manner and this should be problem solved. Many many thanks. Regards RicherT just clarify please - do you have the circuit cables AND the link connected at the same time? Link to comment Share on other sites More sharing options...
arfur mo Posted March 24, 2008 Share Posted March 24, 2008 imo it's pretty obvious you have misunderstood the basic instructions supplied and tried to run before crawling which when doing something new is usually fatal. so do as earlier advised, remove all zone cabling and refit the links, then test to see if the panel arms properly, if not resolve this issue 1st. re-install cables one zone at a time (removing the links one at a time) and test for correct setting at every stage, regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
RicherT Posted March 25, 2008 Author Share Posted March 25, 2008 just clarify please - do you have the circuit cables AND the link connected at the same time? Taking 1 step at time I had 1 pr of PIR of cables connected WITH the link installed and it worked fine. Will carry on the same proceedure one zone at a time. Link to comment Share on other sites More sharing options...
