Porch Surveillance
Map Security
1st quote....try it
I would, if I knew what you were doing.
2nd quote...not all cavity walls are external...the internals do stop between floors...
That would be a partition wall then. A cavity wall will be a full height external wall.
cavity..a hollow space....look it up..oh and you can also get full height partion walls..
you wouldnt know what im doing,it goes against the know it all perspective.. :whistle:
