Wireless
bellman
Have you fitted wireless and how reliable was it.
220 members have voted
  1. 1. Have you fitted wireless and how reliable was it.
    • fitted it and was happy with no problems.
      41
    • Fitted it but had the occasional problem.
      38
    • fitted it and had excessive problems.
      9
    • fitted it had problems, removed it and installed wired.
      22
right thought as much, and how many of the "number...." are visonic wireless ? and which inspectorate passed them ?
I think you need to clarify what your talking about, on a class 6 system "which is no longer needed" you had to record RSSI readings can you tell me where is the regs that it states this must be a number Eg 1 - 10?????? the panel i use will give you in the installer menu a diagnostics's reading of RSSI no signal, poor signal, good signal or a strong signal. If you would like to make a note of the reading from the panel and record them on your paperwork then there is nothing stopping you.
:bruce_h4h:
:bruce_h4h:
:bruce_h4h:
:bruce_h4h:
:bruce_h4h:
sorry, no one said they arn`t so whats getting you turned on?
however the lack of "recordable" so by definition meaningless measurements means you can`t commision this panel correctly, which means you can`t certify this panel to the standards required by our inspectorate
seen as the other guy doesnt understand the difference between grade and standards I`ll ask you instead - what grade (I`ll give you a hint - inc signalling option) should it only be used for?
You talk some rubbish - because its wireless you cant commission it? :hmm:
What standards does your inspectorate dictate that means wireless Grade 2 systems cannot be commissioned and issued with a certificate and if thats the case what are they going to do about all the certificated Grade 2 wireless systems that their approved installers have put out there?
Guest anguscanplay
how do you record a word to 3 decimal places LOL? poor, good or strong isnt enough information
do YOU ever stop to read what someones put - no
did you read what we said in this thread - no
do you understand anything anyone says - no
do you actually have any idea what your on about - no
did i say you cannot have a grade2 wireless - no
did i say you cannot certify a grade2 wireless - no
did i say you cannot have a fully compliant DD243 wirless system - no
As I asked show me where the regs now say what your trying to "not very well i may add"
Guest anguscanplay
listen - do I care? you look them up before your next inspection visit or take the non conf. the choice is yours
:hmm: do you care :hmm:
Well do you ?
You have been bothered enough to reply to every post so far!!!!!!!!
maybe your now showing your true colors you dont have a clue what your on about do you??????? go on admit it we wont think any less of you really.......
:whistle::P
Um, well yes I do and yes you did.
you cant log the commisioning values - therefore it is not certifiable and cannot be connected,
Guest anguscanplay
Well do you ?
:whistle::P
lol no wi5, you obviously want to do things your way - I`ll ask you again though, which inspectorate are you under ( I think we all know the answer to that)
as for the tongue in cheekly named "topalarms"
er no you dont and oh no I didnt - look again and read very very slowly this time
