Veritas 8c
Guest thedarklord_zero
hey there i been reading the Veritas 8c installion manual and does the engineer have a extra pin lets say my pin is 9685 and a engineer comes does he enter a differnet pin?
cheers,
luke
you are correct you will have the master or a user code. The enginer has his own code
pete .................
Any comments/opinions posted are my own and not that of my employers.
usually there are _at least_ three MAINLY different code types in systems:
USER = SET/UNSET
MASTER = SET/UNSET+OTHER FUNCTIONS
ENGINEER/INSTALLER = OTHER/ENGINEER FUNCTIONS
some panels have different levels for user codes.
and :yes: PIN's 99,99% differs from each others.. :-|
anyway of findin it out?
65254[/snapback]
Of course there is, simply tap out the numbers and add 1 each time. :P
0001, 0002, 0003, 0004, 0005 alll the way to 9999, what could be simpler. Ever wondered why your calls out seem to take forever? The engineer's simply forgot the code and is doing the exact procedure above. * :whistle:
* Events described in this post are make believe and may not have actually happened
