Monteey Posted August 9, 2005 Share Posted August 9, 2005 Right i've set myself a little project and need to know where to get certain bits to achieve it. Basically what i want to do is have an external looping system connected to the system whereby a protected cable (probably in some sort of flexi conduit) snakes through some bicycles then back with some sort of waterproof, preferably screw in sleeved connector on the other end. Inside i intend to put a keyswitch to lockout the circuit when the customer needs to disconnect the socket. What im after most is somewhere i can get proper quality external connectors and maybe even decent cable that can stand up to a bit of rough from being threaded through bicycles. Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue Link to comment Share on other sites More sharing options...
PJF Posted August 9, 2005 Share Posted August 9, 2005 For the plugs have a look at RS, the range is called Bulgin Buccaneer(honest). I used these not long ago when installing temp cameras on a ferry boat & found them to be spot on. As for the cable, would you only need a pair ?. What about 1.5 3c artic flex and ditch the third core. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment Share on other sites More sharing options...
Guest Posted August 9, 2005 Share Posted August 9, 2005 You only actually need a minimum of 1 core. If there are any more cores than that then loop the circuit up and down the cores so as to tamper protect it a bit. If you want some decent rigid cable look at armaflex, the braided flex with an overal PVC sheath, v heavy duty. Link to comment Share on other sites More sharing options...
Mavrick_001 Posted August 9, 2005 Share Posted August 9, 2005 Agreed with the man above!!! That's the stuff!!!! It'll look nice too CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER Link to comment Share on other sites More sharing options...
bellman Posted August 9, 2005 Share Posted August 9, 2005 Agreed with the man above!!! That's the stuff!!!! It'll look nice too 64010[/snapback] QFA Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer. Link to comment Share on other sites More sharing options...
PJF Posted August 10, 2005 Share Posted August 10, 2005 I think Lurch means YY cable, correct me if im wrong Lurch. Avaiable from most large elec wholesale. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment Share on other sites More sharing options...
Guest Posted August 11, 2005 Share Posted August 11, 2005 Close, SY. Link to comment Share on other sites More sharing options...
