Menvier 690M problem
breff
I had a weird one with a 690M today, they had a smoke detector activate, silenced it with their code and entered their code again to reset. The keypad locked up at this time and was still locked when I arrived. After multiple presses of the ESC key the system went into code tamper , we entered the code and the keypad went back to normal.
I activated the smoke again and silenced with engineer code, then entered eng menu 1, 0 to user menu 1, pressed ESC, keypad locked up again.
After causing another code tamper to unlock the keypad I then caused an intruder activation and the system silenced and reset with no problem.
I phoned Menvier Tech and left a message as they operate a crappy callback service, and they havent got back to me.
The panel is approx 3 to 4 years old, I think its software version 4.0, there are 8 zones in use, 6 in the panel and 2 in the keypad, the smoke is wired to zone 7 in the keypad.
Anyone had this?
Any ideas?
Anyone had this?
Any ideas?
54868[/snapback]
Not had that fault exactly, but I have had some very random faults on Menvier panels, which were caused by induced AC. Check your levels of indiced a/C, and if they are high fit a 12v spike supressor.
Might be the fault - worth a try!!
D7
Just check menu 1 option 9 - number 34 should be off this is entry keypad lock - it shouldnt make a difference to you but humour me.
D7
54879[/snapback]
Thanks for your input D7, like you say worth a try.
Hmm i doubt it would have that option being 3-4 years old so probably pre-DD243
54914[/snapback]
Spot on Mont, it only goes up to option 29
Bump
Any other suggestions?
Hmm bin it and put in a Premier?  :whistle:
55222[/snapback]
Got one of those premier panels and cant say Im very impressed sorry :(
Got a prem 24 with the LCD prox kit.
Just using it standard at the mo, but which ever way I approach it, its just not to my liking sorry, I still prefer the menvier panels.
I dont want to bitch about it, I got it to try as you where on about them alot (The premier range that is), but I still dont see the fascination or quite how you prefer them.
Each to their own and all that I suppose :)
