Guest Posted February 5, 2005 Share Posted February 5, 2005 If there is 4 cores present he can pull 8 core there using 4 core (if it is possible) later when he needs extra cores.. ? Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2005 Share Posted February 5, 2005 or fit a system in the outbuilding and use the 4-core to trip a zone on the main system Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2005 Share Posted February 5, 2005 or fit a system in the outbuilding and use the 4-core to trip a zone on the main system 39372[/snapback] Eng... I bet you have better ideas.. Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2005 Share Posted February 5, 2005 Eng... I bet you have better ideas.. 39373[/snapback] better than yours yes.... Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2005 Share Posted February 5, 2005 better than yours yes.... 39374[/snapback] Ofcourse, but what i ment was that you have better ideas than "or fit a system in the outbuilding and use the 4-core to trip a zone on the main system". Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2005 Share Posted February 5, 2005 Ofcourse, but what i ment was that you have better ideas than "or fit a system in the outbuilding and use the 4-core to trip a zone on the main system". 39375[/snapback] if the 4-core is in and cant be replaced, to keep to regs its better to fit a slave system.. Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2005 Share Posted February 5, 2005 what reg's are prohibiting to use common 0V ?? Link to comment Share on other sites More sharing options...
Guest Chrisyates Posted February 6, 2005 Share Posted February 6, 2005 what reg's are prohibiting to use common 0V ?? 39388[/snapback] Link to comment Share on other sites More sharing options...
Guest Chrisyates Posted February 6, 2005 Share Posted February 6, 2005 I don't seem to be getting very far with this query, with the exception of the helpful reminder about using a laching PIR. Please note that I cannot replace the four wire between the alarm panel and the outbuilding - I am stuck with it. What I need to know ishow to wire a PIR and two door detectors with a four wire cable. The crux of the question is how do I get power to the PIR? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Adi Posted February 6, 2005 Share Posted February 6, 2005 12v solar panel. I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
