robertjan Posted 13 hours ago Share Posted 13 hours ago Goodevening, I could use some help setting up a Betty Siren (see datasheet attached) on my GD48. My setup is as follows; MK7, Selfmon LCE-K3 and RF Portal C079-2 on the Bus, connected to several DO8M and IR8M sensors. Everything works fine, except my siren, I don't get it working. I connected (+) (blue) to AUX3 and (-) (blue/white) 1001, see attached. In my system 10001 output set to Siren V and neg. Tamper from the siren (white/green and green tot AuxTEMP and GND No sound of the siren when zones are violated. All zones are labelled to intruder and Siren also. Can someone help me out? Thanks so much! Kind regards, Robert Jan Datasheet_Betty_sirene.pdf Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/ Share on other sites More sharing options...
al-yeti Posted 12 hours ago Share Posted 12 hours ago 1 hour ago, robertjan said: Goodevening, I could use some help setting up a Betty Siren (see datasheet attached) on my GD48. My setup is as follows; MK7, Selfmon LCE-K3 and RF Portal C079-2 on the Bus, connected to several DO8M and IR8M sensors. Everything works fine, except my siren, I don't get it working. I connected (+) (blue) to AUX3 and (-) (blue/white) 1001, see attached. In my system 10001 output set to Siren V and neg. Tamper from the siren (white/green and green tot AuxTEMP and GND No sound of the siren when zones are violated. All zones are labelled to intruder and Siren also. Can someone help me out? Thanks so much! Kind regards, Robert Jan Datasheet_Betty_sirene.pdf 155.04 kB · 0 downloads Are you sure the output is set to the word siren can you check exactly what it is? And you are on Rio one not zero, on the right output Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531537 Share on other sites More sharing options...
james.wilson Posted 11 hours ago Share Posted 11 hours ago Try putting the trigger to hard voltage. If it doesn't trigger isn't an output issue securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531540 Share on other sites More sharing options...
