December 4, 2025Dec 4 comment_531368 Hi  I'd be grateful for any advice from anyone with system upgrade knowledge/experience.  I have an installed ADE Optima Compact that is around 24yrs old and needs replacing. I do not want to go down the wireless route but I'm not sure if I'm restricted in alarm system choice that I could upgrade to using all the current original wiring??  I would also like to add an additional key pad at the back door without running an additional wire, I have read some hardwired systems also have wi-fi functionality, is this possible??  Any system recommendations to upgrade to??  Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 4, 2025Dec 4 comment_531374 2 hours ago, mac8985 said: Hi  I'd be grateful for any advice from anyone with system upgrade knowledge/experience.  I have an installed ADE Optima Compact that is around 24yrs old and needs replacing. I do not want to go down the wireless route but I'm not sure if I'm restricted in alarm system choice that I could upgrade to using all the current original wiring??  I would also like to add an additional key pad at the back door without running an additional wire, I have read some hardwired systems also have wi-fi functionality, is this possible??  Any system recommendations to upgrade to??  Thanks Your going to DIY it?  Scantronics ion 40 if that's the case   If not then hkc and others will say texecom?  You said no to wireless then said WiFi keypad , so you mean yes to wireless where needed , most panels these days will offer hybrid options Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/#findComment-531374 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 5, 2025Dec 5 Author comment_531379 Thinking DIY if not too taxing, and correct wireless for the extra keypad, the rest using existing wiring assuming its the same.  I'll have a look at the Scantronics ion 40.  Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/#findComment-531379 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 5, 2025Dec 5 comment_531380 2 minutes ago, mac8985 said: Thinking DIY if not too taxing, and correct wireless for the extra keypad, the rest using existing wiring assuming its the same.  I'll have a look at the Scantronics ion 40.  Thanks There's always taxing problems lol  They still do the free cloud I believe but for DIY it's not bad if you can get your head round it Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/#findComment-531380 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 5, 2025Dec 5 Author comment_531382 Am I right in thinking I could just change the control box and the existing sensors, keypad and bell box would all just wire in?? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/#findComment-531382 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 5, 2025Dec 5 Author comment_531383 13 minutes ago, mac8985 said: Am I right in thinking I could just change the control box and the existing sensors, keypad and bell box would all just wire in?? Probably not the keypad thinking about it! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/#findComment-531383 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 5, 2025Dec 5 Author comment_531384 22 minutes ago, al-yeti said: There's always taxing problems lol  They still do the free cloud I believe but for DIY it's not bad if you can get your head round it 🙂 I feel confident to give it ago, just trying to understand wiring compatibility between units and if I can add wireless to hardwire, which I now believe I can. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/#findComment-531384 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 5, 2025Dec 5 comment_531385 9 minutes ago, mac8985 said: 🙂 I feel confident to give it ago, just trying to understand wiring compatibility between units and if I can add wireless to hardwire, which I now believe I can. Well if you use supervised loop then you will save two cores at each detector  Currently you might have a global tamper , but you won't need that Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47417-alarm-upgrade/#findComment-531385 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
