Good evening all.
Requesting a little help from the good folk of the security installer.
I have a pair of Pyronix internal twin alert speaker / sounder units that I'd like to wire into the above mentioned Texecom Premier 24 control panel.
I've attached a couple of pictures showing both the speaker / sounder connections and the control panel connections.
If some kind person would kindly give me the correct wiring connections between the two it'd be much appreciated.
Thank you and regards, Dave.
  • Like 1
1 hour ago, sixwheeledbeast said:
Like most sounders the Twin alert manual has the wiring instructions for different manufacturers.
Aux Tamp / Aux Tamp / Bell / Spk- / 0V / +12V
Thank you.
(I don't have the wiring instructions, this kit came to me as previously used)
  • Like 1
Register a new account
Sign in
