  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Elmdene 8 ohm speakers reduce volume
I have 2 of these run in series and the customer is saying they are too loud
They are connected to a Texecom Premier Elite 24 and being used with the Chime facility
Is it possible to dial down the volume by wiring in something that’s adjustable so they can fiddle with it themselves and then I don’t have to keep adjusting it myself
The product is this one:
Pyronix Enforcer wireless kit 3
  • 3 weeks later...
As above reply said, the premiers do have the changeable tones. You can do it by: Engineer Code -> Global Options -> System Options
Edit: Sadly the cxt would have to ask you as it's only accessible via eng menu.
Thanks 🙂
Edited by AlarmsGalore
There is some volume adjustment in the Master User menu but it's less flexible than the engineers options.
