Where to find extended z&L for maglocks?
I guess this is a bespoke thing, but if it is possible to find anywhere from the shelf to buy where could I get an extended "L" for maglocks? I need it for external use maglocks. In worst-case scenarios, I would drill myself the holes to match.
buy a bit of box section ali & screw it to the door, screw the z bracket or l bracket to it ?
you can buy box section caps of ebay if needed ??
  • 1 year later...
