Claus Posted May 3, 2023 Share Posted May 3, 2023 Hi alarm experts I bought a complete Risco system and are playing with it here on the table before starting the install. It will be replacing a 25 years old Karizma Plus system. I have most of the stuff configured, but there are still some things not working. I installed 4G card with voice, voice module and the panel is connected with ethernet cable. Risco Cloud is configured and working. To be able to use SMTP, I created a free account on smtp2go.com and tested it is working. In Configuration Software I entered the following: Mail host: mail.smtp2go.com SMTP port: 2525 Email address: "the verified sender email used on smtp2go" SMTP user name: "the smtp user name on smtp2go" SMTP password: "the correct password" I then do a FM email test from the panel. Absolutely nothing happens. I get no email, and I can see on smtp2go that nothing tried to use this smtp user. Tried to change the host name to "103.2.140.82" and tried different port like 587 and 465. No change. FM is set to use my private email address as the receiver. FM test is working with SMS and voice. I cannot find any documentation describing of the SMTP use encryption or not, or if there is any other special requirements. I'm a DIY installer, so I do not have access to Risco support. Any help will be highly appreciated Kind regards, Claus Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45589-risco-lightsys-smtp-setup/ Share on other sites More sharing options...
james.wilson Posted May 3, 2023 Share Posted May 3, 2023 some SMTP services are finicky. maybe try Gmail to test etc securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45589-risco-lightsys-smtp-setup/#findComment-519177 Share on other sites More sharing options...
Claus Posted May 4, 2023 Author Share Posted May 4, 2023 Hi James I have now tried almost all combinations of smtp.gmail.com and smtp-relay.gmail.com (and their IP adresses) with all ports. Nothing. Have you ever seen an example of Gmail SMTP setup? Kind regards, Claus Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45589-risco-lightsys-smtp-setup/#findComment-519182 Share on other sites More sharing options...
james.wilson Posted May 5, 2023 Share Posted May 5, 2023 I don't use it myself as I host but https://support.google.com/mail/answer/7126229?hl=en#zippy=%2Cstep-change-smtp-other-settings-in-your-email-client securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45589-risco-lightsys-smtp-setup/#findComment-519188 Share on other sites More sharing options...
jcn Posted January 17, 2025 Share Posted January 17, 2025 I've got a similar problem with the email function. I had to setup a local smtp relay on my lan, without TLS auth. Which forwards to gmail / outlook etc. However, the box only ever sends test message. Both manually triggered emails via the grand master setup or the periodic test messages setup via the installer get sent. But it never sends any arm / disarm, alarm etc messages. All messages types are enabled in the setup for the FM1 / FM2 and both get the the periodic test message. Logs on the smtp relay only show attempts to send test messages. I've left the alarm panel in alarmed state for a while and nothing happend. Cloud works ok, Any ideas? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45589-risco-lightsys-smtp-setup/#findComment-527537 Share on other sites More sharing options...
