Scantronic 9448+ style mains power LED is pulsing
Hi hope you can help i have a Scantronic9448+style and in the night turned light on and tripped out but since resetting the top left LED which normally glows is pulsing ! I’ve tried resetting without success .
Any advise would be appreciated
thanks in anticipation
When was it last serviced?
Power LED flashing on most systems indicates power failure or battery low voltage
