Visonic powermax complete
Hi James thanks for helping me out am getting there now so in define zones menu I take it I can setup all the contacts and pir's for away and home settings in that menu is that correct
Kind regards
Naeem
  • Replies 25
  • Views 2.9k
Hi James sorry to bother you again what settings should I pick to use in D6 define zone menu  to  use zone 2  for away full arm  as well as for home in night time so does not activate please
Kind regards
Naeem
chnage the zone types to either perimeter or interior
An interior zone will only we armed when away
Perimeter Zones
Perimeter zones rely on detectors designed to protect
doors, windows and walls. An immediate alarm is initiated
when such a zone is violated by opening the door/window
or by trying to break the wall
Hi James thankyou so much for all your help and advice  very much appreciated will let you know if I have any problems
Kind regards
Naeem
Hi James I just received from a supply a modual for connecting a hardwired bell but module looksto small and won't fit correctly please can you check my pic of module he sent to me
Kind regards
Naeem
Ok thanks for getting back to me do you know if this 1 is the correct 1
Visonic Powermax Complete Expander Module 9-100775
Kind regards
Naeem
Hi James it's ok I fitted it now thanks once again for getting back to me your help and advice is wonderfull always
Kind regards
Naeem
Hi James I bought a new door contact I installed it and set it to say front door and chime but when the system is not armed and I open the from door it does not say anything can you help me please
Kind regards
Naeem
