sixwheeledbeast Posted March 30, 2023 Share Posted March 30, 2023 That's a few decades earlier Quote Link to comment Share on other sites More sharing options...
Nelboy Posted April 3, 2023 Author Share Posted April 3, 2023 On 30/03/2023 at 09:17, sixwheeledbeast said: That's a few decades earlier yep, got a date code of 1985 on the main chipset... the bugger is older than me! Quote Link to comment Share on other sites More sharing options...
Nelboy Posted April 24, 2023 Author Share Posted April 24, 2023 *BUMP* In a little bit of spare time I have tried the terminal connections on the CIO Adapter and have now got the unit to power up. A green LED on the front is lit up static, a second (possibly yellow) LED is unlit, and a third LED in blue constantly blinks on and off.... to me this seems like a 'blank' start, with the blue LED indicating no programme is held in memory - however without any form of documentation I am unsure on this. If anybody has any PDF's or similar clearly showing the terminal block connections with a wiring diagram, the definition of the front status LED's, and if it can be programmed directly through the 9-pin D-SUB socket rather than as part of a Camdisc system, then I'd appreciate it as online searches are bringing up jack. Quote Link to comment Share on other sites More sharing options...
