sixwheeledbeast Posted February 22, 2023 Share Posted February 22, 2023 Upto 13.9Vdc is what I would usually consider fine, but this is all part of servicing to make sure the voltage regulator is still ok. It's down to design, you need the headroom from the regulator to charge the battery correctly. Transformer output will be around 19Vac for example. PIR's are all different but usual working voltages will be 11-15 ish. As long as there isn't a random device, junction box or other joint somewhere, paint by colours should work fine. 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45496-replacing-a-couple-of-ancient-faulty-pir-sensors/page/2/#findComment-517938 Share on other sites More sharing options...
JimD Posted February 22, 2023 Author Share Posted February 22, 2023 That's good to know swb. Thanks. I've verified that the fault indications are gone with the links in the box removed and the PIR contacts shorted together, so all good there. I also found the red & black cores of the garage cable (with great difficulty though - I'm afraid it's a rats nest behind the circuit board) so I've pushed the button on ordering 3 of those PIRs. I may be back to this thread once the gear arrives. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45496-replacing-a-couple-of-ancient-faulty-pir-sensors/page/2/#findComment-517939 Share on other sites More sharing options...
JimD Posted February 24, 2023 Author Share Posted February 24, 2023 So the PIRs arrived yesterday, and I'm looking to fit them today. Is there a simple way to deactivate the 12v supply to the PIRs on this panel (e.g. remove one of the fuses)? I don't want to power the whole panel down as the external siren will go off if I do (don't ask how I know). The only manual I can find is slightly different to the model I have (it's for a unit with 8 zones and mine is 6 zones) and doesn't really help me with that. I suppose I could just remove the most likely looking fuse and stick my meter on the 13v output, but that risk a lot of noise happening. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45496-replacing-a-couple-of-ancient-faulty-pir-sensors/page/2/#findComment-517951 Share on other sites More sharing options...
sixwheeledbeast Posted February 24, 2023 Share Posted February 24, 2023 disconnect the wiring. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45496-replacing-a-couple-of-ancient-faulty-pir-sensors/page/2/#findComment-517952 Share on other sites More sharing options...
JimD Posted February 24, 2023 Author Share Posted February 24, 2023 16 minutes ago, sixwheeledbeast said: disconnect the wiring. That's an option - is the inevitable 'noisy' reconnection likely to make the PIRs misbehave at all? The instructions for the new ones mention some sort of 'self test' on first power up. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45496-replacing-a-couple-of-ancient-faulty-pir-sensors/page/2/#findComment-517953 Share on other sites More sharing options...
JimD Posted February 24, 2023 Author Share Posted February 24, 2023 (edited) I just disconnected the 12v wires in the box and all was fine when I reconnected them after fitting the new PIRs so I was worrying about nowt really. Just the new one to fit in the garage left to do, and that's for another day - I'm confident I can handle it now though. Thanks to everyone who replied to my questions - I appreciate the help I've had from this community. (Edited to add pics) Edited February 24, 2023 by JimD Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45496-replacing-a-couple-of-ancient-faulty-pir-sensors/page/2/#findComment-517955 Share on other sites More sharing options...
